Old 09-02-2007, 01:39 AM
spddmnjay spddmnjay is offline
Originally Posted by JamesD
Best looking color combo for the viper coup imo. That car is sex on wheels.
Yeah Baby, Yeah...Sex on wheels!!
spddmnjay
1996 Viper GTS Venom 550 Hennessey
2006 Ford GT - Tungsten Lemans 1-2-3 Commemorative
"Too fast?? It's never too fast!"
Old 09-05-2007, 09:15 AM
These are the brakes after I detailed them. I polished the center of the front rotors and painted the center of the rear rotors. I also installed high temp Venom 550 decals on the calipers.
spddmnjay
Old 09-05-2007, 09:30 AM
These show the intake manifold during and after removal of powdercoating. The powdercoating was extremely difficult to remove even with industrial air craft paint stripper.
spddmnjay
Old 09-05-2007, 09:40 AM
I purchased Gen. III Viper valve covers to install on my Gen. II engine. I'm going to change the valve cover color to match the intake manifold. These show the valve covers before, during and after powdercoat stripping.
spddmnjay
Old 09-05-2007, 09:50 AM
In front of the engine is a cross brace that spans the width of the engine compartment to provide support to the upper frame. This support is aluminum and I decided to detail it. The pics show the brace before and after polishing.
spddmnjay
Old 09-05-2007, 09:57 AM
68protouring454's Avatar
looks good, more then likely it was powdercoat not paint, it does not like to come off, acts like rubber
Jake's Rod Shop
Old 09-05-2007, 10:01 AM
GvEman's Avatar
GvEman GvEman is offline
Sweet! I was surfing the net and found a picture of The Hennessey Venom 1000 twin turbo engine, man that intake is awesome! I gues thats a III gen engine so i dont know if it fits your engine, but it would look awesome.
But i am sure you will make that intake look Top notch!
Keep it up!
Old 09-05-2007, 10:06 AM
Yes you are correct...the original intake coating is powdercoating and a huge paint to remove. I will edit my text above to indicate powdercoating.
Jason
spddmnjay
Old 09-05-2007, 10:07 AM
I am a stickler for consistency and therefore decided to paint the half shafts silver in color to look somewhat similar to the drive shaft which is aluminum. I also polished the aluminum drive shaft to clean it up. Pics are before and after painting and polishing.
spddmnjay
Old 09-05-2007, 10:14 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Maybe I missed it, but what are those rear rotors off of? They look like they were a 5 lug rotor, drilled to work with your 6 lugs.
What size are they?
