Old 09-06-2007, 01:21 AM
street3285 street3285 is offline
That looks like a nice kit for smoothing the firewall. How much does that usually go for? Does it fit well?
Would you still want to use FUSOR?
Old 09-06-2007, 03:44 PM
rocketrod rocketrod is offline
I am currently smoothing my firewall, click the link for details http://www.camaros.net/forums/showthread.php?t=98442
Rod
1969 Camaro - LS2/4L70E
Old 09-09-2007, 11:36 PM
Cars look great. Once I start the smoothing I will post some pictures.
Thanks for the great info guys.
Old 09-25-2007, 01:49 PM
jaronson jaronson is offline
We cut all the bumps from the firewall then made a cardboard template. That was then turned into a single sheet of steel to cover the entire firewall.
When you cut all the bumps off the firewall did you cut out the raised portion around the master cylinder and steering column hole or did you just sheet right over it and cut new holes?
It is slightly raised, but I wasn't sure if it would be enough to notice once covered.
Thanks for the help.
Old 09-25-2007, 02:21 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
The templates I got go around the steering plate. I think that is what most people are doing.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 06-23-2009, 02:10 PM
av8or32 av8or32 is offline
Is it possible to smooth out the passanger side section of the firewall with the motor in the car?
