Old 09-30-2007, 08:07 AM
Default Undercarriage pics of mufflers - plese
Hello!
Can somebody post pics of exhaust systems with flowmasters in a first gen with minitubs. My idea is to mock up mufflers to see there is enogh space and make more if theres not. Basicly the question is are the side in / center out the ones wich mounts the best ?
63 Z06
Old 09-30-2007, 06:15 PM
rsk68's Avatar
rsk68 rsk68 is offline
https://lateral-g.net/forums/show...0040#post90040
not flowmasters but should be close enough.
RSK68
Rick Klein
Hood-latches.com
Cast Aluminum hood latches.
Old 09-30-2007, 10:11 PM
Thank you Rick!!
I got the idea. How do you like the Vbands? Do the work on "street" ?
I was planing to use em from headers to the end.
63 Z06
Old 10-01-2007, 08:13 PM
sunset68's Avatar
sunset68 sunset68 is offline
Default Best I got...
http://i99.photobucket.com/albums/l2...dymufflers.jpg
68 Sunset Orange Metallic Camaro
Old 10-01-2007, 09:51 PM
Some thoughts... or brain farts you deside
I ordered 50 series deltaflows and plan useing them as mockups to check i there any need to make more space for mufflers. Since the car is now on body dolly its pretty easy to fab more room under the rear seat.
I want to run 3" ´system as tight as possible .
63 Z06
Old 10-02-2007, 06:54 AM
rsk68's Avatar
v bands are high quality parts but i have not run it on the street yet.
RSK68
Rick Klein
Hood-latches.com
Old 10-02-2007, 07:35 AM
Payton King's Avatar
Default Mine is a 3 inch system all the way
back with an H pipe. It is as tight to the car as you can get it. Inlet uses offset, center on the outlet. I am running Magnaflows...they sound really good on a LSX motor. The mufflers are only 14 inches long and you can see straight through them.
Hopefully the car will be on a lift friday and I will shoot you some shots of it coated and complete
