  #33
Old 11-02-2007, 06:41 AM
2ndgenracer 2ndgenracer is offline
I'm still finishing the scoop, but I plan on running a K&N panel filter at the back of the scoop, and seal the carb to the scoop with foam. I found that K&N has a killer website where you can search filters by dimension. Punched in the numbers and it came up with three filters, used the cross reference and found the standard filter at the Zone and I'll make sure it will fit with little modification, and then I'll order the K&N.
