Old 12-09-2004, 05:41 PM
Musclerodz's Avatar
Default Centerforce Dual Friction Clutch
I need to buy a clutch and can't make up my mind. I posted this over at PT.com but got mixed results. For those that have ran them, what are your thoughts and would you run one again. Thanks in advance.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-09-2004, 06:40 PM
camcojb camcojb is online now
Mike
Mike,
I've had extremely good luck with the Centerforce dual frictions. I've had them behind 600 HP in a couple of cars and Don has it behind his 691 rwhp Camaro. No problems at all. Now if it was a drag race application with slicks and boatloads of power I may go with a twin disc, but for some healthy street setups it works very well.
Old 12-09-2004, 06:49 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Mike, I used a CenterForce DF behind my 434 with the TKO. I thought it worked awesome. If I had to do it over again, I would buy the same clutch.
Some of the mixed reviews may have been coming from the late model guys. I've heard that CF isn't a good choice for 4th Gen F-bodys.
https://lateral-g.net/gulbranson/...terforcedf.jpg
My LS7 69 Camaro
Old 12-09-2004, 06:58 PM
Blown353 Blown353 is offline
I'm having extremely good luck with my Weber/Mcleod Dual Performance. It's similar to a Centerforce dual friction (organic material on the PP side, and bronze on the flywheel side) but without the little "finger" weights. Good smooth takeup, surprisingly light pedal effort, and I haven't felt it slip even under wide open throttle in 4th gear.
I've had a friend who had a couple of weights in his Centerforce DF let go, it wasn't pretty (little holes in his stock bellhousing.) That seems to be an exception though.
Also, you can't balance a Centerforce pressure plate because of the little weights, so you may or may not have a slight vibration.
If it's just a street car that won't be seeing any repeated slick usage at the strip, I'd recommend either. They both work very well for a high-HP street application.
Here's a pic of my Weber/McLeod setup, the disc is sitting metallic pad (flywheel side) up.
Troy
1969 Chevelle
Old 12-09-2004, 09:10 PM
Musclerodz's Avatar
The weights were a complaint over at PT.com. He said that the pedal engagemant postion was not the same at all rpms. Is this something that any of you have noticed? I am not fond of not being able to balance it if I can with a McLeod or the flyweight issue.
Mike
Mike Redpath
facebook page
Old 12-09-2004, 10:03 PM
The pedal effort, not the take up position, will change with the RPM on a Centerforce with the weights. As you spin it faster, centrifugal force tries to pull the weights out, which puts more pressure on the fingers of the PP spring and more pressure against the pressure plate, increasing clamping power. Thus, the higher you rev it, the "stiffer" the clutch will feel since the weights will be exerting more force on the fingers.
It's weird at first but you get used to it quick.
As far as your last question/statement, yes you can balance a McLeod Dual Performance since the PP is a standard diaphragm type with no floating weights.
Troy
1969 Chevelle
Old 12-16-2004, 08:59 PM
lil427z's Avatar
lil427z lil427z is offline
Thumbs up center force
mike, I've had extremely good luck with the center force dual friction setup. I have a 427ci sbc , hilborn efi , richmond 6 spd, ford 9' with 370 gears .
It made a little over 550 rwhp.
The 73 camaro z28 / rs and me and my girl have done 2 hot rod power tour
2003 and 2004 long haul .
rick kirkindall
Old 12-17-2004, 05:49 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
I have one and love it. At the time of purchase, I called CF and asked for a higher rated disc. They cross referenced to a heavier car which had a different disc material compostition. This is on a 69 camaro vert.
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 12-17-2004, 09:01 AM
Jay Hilliard's Avatar
I got my clutch and pressure plate from Johnny's Transmission Clinic ... 860-423-8463. I got it 2 years ago and no problems in my 69 camaro with 400 rwhp. He hand builds the clutches, etc.
He was recommended to me by the tech guys at Tex Powell Racing Transmissions, where most NASCAR teams get their trans. Johnny is very nice guy to deal with and he also builds clutches for the modified race cars up north. One of his long time clients was Steve Park.
Just throwing another choice out there. Centerforce makes good products also.
Jay
Jay
Old 12-17-2004, 04:20 PM
Musclerodz's Avatar
Rick(lil427Z),
That is a killer second gen. I saw you coming in at the Tulsa Power Tour stop as I was leaving. The second gen Camaro is the only one I have not owned......YET!
Jaybird,
How are they priced compared to Centerforce, and where are they located? I really want a clutch with a balanced feel at all rpm. Right now that is my only drawback to the Centerforce DF clutch. I don't want to fight it.
Mike
Mike Redpath
facebook page
