Old 07-10-2005, 08:10 AM
MaxHarvard's Avatar
Default Vapor lock?
Any good tips on how to get rid of it?
It only happens after a long (over 1 hour) drive and i slow down and idle. the car is a 1968 camaro with a small block. stock fuel tank, stock fuel pump.. 750 demon carb, 1" phenolic spacer.
Any help?
Old 07-10-2005, 08:42 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Eric, make SURE your gas cap is venting. I had the same problem years ago and it was a bad cap that wasn't that old.
My LS7 69 Camaro
Old 07-10-2005, 06:30 PM
BC69's Avatar
BC69 BC69 is offline
That makes me ask this ? as far as its "venting"...when I drive for a decent amount of time...20min or so and then stop for gas. When I take off the cap there is a POP and a Whoosh of fumes...the cap is supposedly a venting cap,but my thought is it isnt venting..
Agreed?
Tim
In memory of those gone before us
In gratitude for those who care.
Old 07-11-2005, 06:44 AM
MaxHarvard's Avatar
Agreed?
Tim
Mine is doing the exact same thing!! How do i find a vented cap for a 68?!
Old 07-11-2005, 07:01 AM
XcYZ's Avatar
The restoration places carry them; Ricks, Year One, Classic Industries, etc.
My LS7 69 Camaro
Old 07-11-2005, 07:42 AM
MaxHarvard's Avatar
Ahhh ok, i hope this works... its only after long drives... really weird.
Old 07-11-2005, 07:53 AM
BC69's Avatar
What is the best cap? Are there aftermark ones that are better? I just went to yearone.com and found what is supposedly the 69' vented cap...it is exactly what I have. My cap has VENTED stamped on it, so I just dont think buying the same cap again will make a difference.
Didnt I read a long time ago about someone drilling a small hole in their cap. Wasnt that you Scott? Or am I just nuts.
Tim
Old 07-11-2005, 08:16 AM
XcYZ's Avatar
Tim, you have a good memory. That was me that drilled a 1/16th hole in the cap as a troubleshooting measure. At the time, it was extremely hit or miss. The car would die once a week or maybe once a month. It was acting like an electrical problem, but as it turned out, the cap was acting goofy, it just didn't fail, it was intemittent or vented extremely slow. The hole I put in the cap fixed the problem, but I ordered a new one for obvious reasons.
My LS7 69 Camaro
Old 07-11-2005, 08:28 AM
MrAngry's Avatar
MrAngry MrAngry is offline
The same exact thing happens to me with my 440 68' Charger. Only happens after about 1 hour of constant driving. I have a vent hose from my gas cap that I blew out with my air compressor - thought that may have done it, but then it actually happened last night after an hour drive, totally annoying. I also have a spacer under the carb. - I've made sure all fuel lines are clear from any substancial heat sources i.e. headers, exhaust. I have also replaced the fuel tank and sending unit. I may try heat wrapping the fuel lines as I don't what else to do.
Old 07-11-2005, 12:52 PM
Y-TRY Y-TRY is offline
What is the symptom of vapor lock? I know causes but don't know what it feels like. Does the engine just stop abruptly for a second?
