Old 02-08-2008, 02:48 PM
rocketman's Avatar
I would run either 18/20's or 19/20's to give it alittle balance
Old 02-08-2008, 04:42 PM
71OLDS's Avatar
71OLDS 71OLDS is offline
Jon,
How harsh was the ride w/that 245/35/20 on the front? I was thinking a 40 series in a 19 might be better for the front but I like the Nitto 555 and they don't make any. My current 255/45/18s are real smooth. Will I be feeling every pebble on the road w/the 35s?
-Joe
Joe Lincoln
1971 Olds 442 Convertible & 1970 Cutlass Supreme
Old 02-11-2008, 11:52 AM
DriverzInc DriverzInc is offline
It was a 245/30/20 front, and I bent a rim after only one month. Won't do that ever again. I am currently running a 245/35/19 on the front of my chevelle, with a 285/30/20 rear, and it's a little harsher than the 17's that were on it before, but I can deal with this set up. Suspension is set up right though which makes the real difference. Global West uppers, lowers, with springs, and gas shocks. I plan on upgrading to Vari-shocks from Chris Alston's so I can dial in the ride a little better.
Old 02-11-2008, 11:59 AM
slownova slownova is offline
i have a 19x8 and a 22x11 on my 70 chevelle. i wouldn't trade them for anything. stock wheel wells also
Old 02-11-2008, 11:08 PM
gionni's Avatar
gionni gionni is offline
do you have pictures of your chevelle???
"PRO-RUNNER" 1971 Plymouth Road Runner
408cui Stroker (510HP/520tq), Keisler A41 Overdrive AT, Budnik's 19"/20", AlterKtion suspension with airride, Street-Lynx 4-link suspension rear with airride, 14" Wilwood 6-Piston brakes, custom interior...
Old 02-12-2008, 09:58 AM
its the same car you commented on on pro-touring
Old 02-12-2008, 11:00 PM
gionni's Avatar
yep, i have seen it later...
Old 02-13-2008, 06:01 AM
Jmartorana's Avatar
Jmartorana Jmartorana is offline
Originally Posted by 71OLDS
Jon,
-Joe
Joe
I just did poly bushings and went to 18" rims w 235 & 275/40's series tires from 15 and 60's and the ride was very different (harsh). Initially I thought it was from the change in bushings but I reduced the tire pressure from 48 psi down to 35 psi and it made a world of difference cruising around.
