1969 Camaro rearend width?
Mark Forums Read
02-21-2008, 06:43 PM
unwrittenlaw191
What is the stock width on 69 camaro? Also with running a DSE mini-tub how much narrower can you go and still get an avalible backspacing?
Dustin
unwrittenlaw191
Find all posts by unwrittenlaw191
2
02-21-2008, 06:58 PM
68protouring454
60 inch is stock width.
55 to 55.5 or so is the common width for use with a 12 inch wheel and 6 inch backspacing.
Jake's Rod Shop
07:35 PM
68protouring454
Find all posts by 68protouring454
3
02-21-2008, 07:17 PM
unwrittenlaw191
I am sorry is this backing plate to plate or axle to axle or....?
07:35 PM
unwrittenlaw191
4
02-21-2008, 07:36 PM
68protouring454
this is axle flange to axle flange
Jake's Rod Shop
68protouring454
5
02-21-2008, 07:44 PM
ItDoRun
Call DSE. They were very helpful.
Chris
Build Thread:
https://lateral-g.net/forums/showthread.php4?t=19253
ItDoRun
Find all posts by ItDoRun
6
02-21-2008, 08:21 PM
ProdigyCustoms
Yup, Jake is correct. We sell and install lots of Mosers for mini tub, 55" flange to flange (including rotors / drums) and 6.2" backspace and you have a tick of wiggle room to shim if you need to.
Frank Serafine
ProdigyCustoms
Find all posts by ProdigyCustoms
7
02-23-2008, 10:14 AM
67rstbkt
Would these same dimensions apply to a 1967? I'm planning on DSE minitubs but with a 17x11 rear width.
67rstbkt
Find all posts by 67rstbkt
8
02-23-2008, 11:55 AM
ProdigyCustoms
With a 11" wheel I would do a 5 3/4" Backspace with a 55" rear.
Frank Serafine
ProdigyCustoms
9
02-23-2008, 06:26 PM
67rstbkt
67rstbkt
Email this Page
Linear Mode
Switch to Threaded Mode
12:58 PM
