Old 03-04-2008, 08:32 PM
TOM NELSON TOM NELSON is offline
Default LS7 Warhawk Twin Turbo mid engine
It's been awhile since i posted i fiqured i would chime in and show you guys the motor thats on the dyno right now.427 cube warhawk with twin turbo twin injectors per cyl.The dyno set up was really a pain but we are running everything including the mufflers.Heres some shots and a base 7 pound pull basically i fige it will make around 830hp at 7psi pretty insane.keep in mind this will make 39 psi we will lean on it this week all keep you up to date on it.
Old 03-04-2008, 08:35 PM
GHOSTDANCER GHOSTDANCER is offline
Old 03-04-2008, 08:37 PM
Default Dyno Graph
Dyno Sheet
Old 03-04-2008, 08:53 PM
Project_Gotham Project_Gotham is offline
Nelsonsupercars # 002 ???, Mid Engine???? Motor is badass! How about some details on what it goes in !?!?! What does mad scientist Mr. Nelson have brewing up?
--Mark Stielow Wannabe--
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
2014 Chevrolet SS Sedan
Old 03-04-2008, 09:28 PM
Default shots of it installed
heres some shots of it mocked up,and the car
Old 03-04-2008, 09:36 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Absolutely stunning, Tom!
My LS7 69 Camaro
Old 03-04-2008, 10:33 PM
Default tt lsx
Thanks Scott
Old 03-05-2008, 02:45 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Originally Posted by TOM NELSON
It's been awhile since i posted i figured i would chime in and show you guys the motor thats on the dyno right now.427 cube warhawk with twin turbo twin injectors per cyl.The dyno set up was really a pain but we are running everything including the mufflers.Heres some shots and a base 7 pound pull basically i fige it will make around 830hp at 7psi pretty insane.keep in mind this will make 39 psi we will lean on it this week all keep you up to date on it.
Ok, you win!
How much for the WarHawk? (As seen above)
How about a Warhawk with, "YOUR", TT kit? <-------This one is meant to be really serious.
Thanks for the post. That car would make a good, "Center Fold".
Ty
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
Old 03-05-2008, 07:10 AM
DDY RCKT's Avatar
DDY RCKT DDY RCKT is offline
That's an amazing motor, and the car looks pretty nice, too. Excellent job!
2002 Corvette Z06
Old 03-05-2008, 09:03 AM
Nate_ERC's Avatar
Nate_ERC Nate_ERC is offline
Nice.
www.eckertsrodandcustom.com
