Old 03-26-2008, 01:22 PM
almcbri's Avatar
almcbri almcbri is offline
thanks for the info. I guess (venamous type) sold me some junk off of his 68 camaro.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 03-26-2008, 02:42 PM
hotrodf1 hotrodf1 is offline
Hold on - I wouldn't throw them out yet. Get a motor in there.
I had to cut my Hotchkis front coils as well to get it to sit decent (even though they are supposed to be a lowering spring). And they didn't seem to droop any more after miles were put on the car.
I can get them in and out without having to compress the springs too (of course the suspension is at full droop at this point).
Car had a nice stance, about 3 or so inches of susp. travel before bottomed.
I will say one thing, those springs are stiff, I used stock gas shocks, and they weren't enough. I would get the revalved Bilsteins that Hotchkis has available, like $100 EA, unless you decide to go adjustable or something. I think those coils are in the neighborhood of #600lb/in. rate or so, but I'm not for sure on that.
Good luck.
Old 03-26-2008, 04:30 PM
eville's Avatar
eville eville is offline
Just wait and see once you have your motor in.
I have the hotchkis springs in my car with AFX spindles (.75 drop). I'll need to cut my coils a bit to get the car a little lower.
When I put mine in, I did not need a spring compressor.
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
