Old 04-06-2008, 04:21 PM
chicane's Avatar
chicane chicane is offline
First, which Holley pump is it and where is the pump located ?? What is the line size ?? Are you running a regulator ?? Is it set up as a bypass ?? And if you are, what is the fuel pressure at idle ??
Sounds like the pump may be hitting a pressure head, therefore unessarily loading the pump and it is thermally shuting off... which is not good.
