Closed Thread
Old 05-29-2008, 10:01 PM
Looks good I'm glad I stayed up late , got to see new update.
Wayne
  #212
Default Wiring
I have alot of time in wiring. Most of the front end is wired just waiting on my Vintage air kit and my dual fan setup so I don't have to back track. Everything from the fuse block back is done. I am also waiting on the AC so I can cut my hole for the AC controller. I want to wire the AC/Heat and gauges before the column goes back in. Really could turn the key in a little of no time. I want to get it to the point I can back it out of the garage before the key turns. Here is a glimpse at wiring.
  #213
Old 05-29-2008, 10:04 PM
I can't wait to see it run !
  #214
Old 05-29-2008, 10:06 PM
I have Tyler at ATS making me a crossmember. As soon as he is done I can order my drive shaft and cut my shifter hole.
Headers are out at the coater and should be done tomorrow. Went with the same coating as before just due to the heat disipation. I liked the black when I had it mocked up but want to cut down on heat as much as possible. Once the headers are in..I can start stacking in my Z bar, column, master cylinder..etc.
Dual fan setup should be on it's way.
Vintage air was ordered from Frank last week. Hope to see it no later than the beginning of next week.
Should have front brakes showing up anyday now as well.
  #215
Old 05-29-2008, 10:08 PM
You must be nipping at the bit to get it running.
Wayne
  #216
Old 05-30-2008, 10:06 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Todd your making awesome progress! I might have to stop in and have a look.
Curtis
  #217
Old 05-30-2008, 10:12 AM
Come on over anytime...and I can see the light at the end of the tunnel. Can't wait to fire it up and piss off the neighbors.
  #218
Old 05-30-2008, 10:56 AM
Rybar's Avatar
Rybar Rybar is offline
Looks awesome Todd, nice progress!
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
  #219
Old 05-30-2008, 04:14 PM
skatinjay27's Avatar
man todd your jamming on that car esp. cause your doing most of it alone too.
i need to come by a see that car now since it sporting LOTS more parts than the last time i saw it!!!
AJ
  #220
Old 05-30-2008, 05:39 PM
Efi69Cam Efi69Cam is offline
[QUOTE=Vegas69;151207]Power steering is almost done. I need to call DSE in the morning. I can't get a fitting on the pressure side of the rack. Probably going to need a 45 right out of the rack to get a fitting to screw on. Anyway, breather system is complete. Power steering resorvoir and all the other lines are done.
Are you using small or big block frame stands? Dan @ Lemon's told me he prefers the fit with the small block mounts.
Closed Thread
