Old 07-20-2008, 12:42 PM
youthpastor's Avatar
that is the nicest cleanest way to do it. I could not do that on mine because the engine is set back 1.5" further than normal, and there wasn't room on the passenger side between the head and firewall.
I ended up moving mine under the motor.
Jody- that looks awesome- I Just might copy that- did you make the brackets or is there a kit
Old 07-20-2008, 01:10 PM
I made the brackets/spacers for that setup. Started with this:
Then added this. A couple right angle braces off the pan studs hold this in place.
Then added one additional brace from the bellhousing and ended up with this; it is very solid, can't move it at all.
Old 07-20-2008, 01:13 PM
the other option is to make the simple all-thread and spacer setup in the first pic, and then simple brackets off the studs to holes in the back of the heads like DSE did. I would do this first if there's room on your install. Got this simple idea from Tony (Nineball) at LS1Tech.
Old 07-20-2008, 01:39 PM
ironworks's Avatar
I know Tyler @ ATS has new bitchin ones that might already be avalible. You should give him a ring.
Rodger
Old 07-20-2008, 03:48 PM
Rodger
yes, I've been amazed that somebody hasn't come up with a clean billet mount that bolts to the back of the head, and a universal one for mounting wherever. Seems like there's a market for them.
Old 07-20-2008, 04:14 PM
James OLC's Avatar
Rodger
Tylers coil mounts are really really cool.
They are going to offer a ton of options for locating the coils are absolute works of art.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 07-25-2008, 08:20 PM
James OLC's Avatar
These are the coil brackets that we are using on the OneLapCamaro:
The machine work is awesome and they fit the coils perfectly.
I still need to work out what to do with the hardware but I think that they have a ton of potential.
These are prototypes that we had machined for us by Matt at RFR. The final product will be anodized but we wanted to evelate the design before moving forward.
James
1969 Camaro - Dusty
