Old 07-26-2008, 10:55 AM
rallye455 rallye455 is offline
Thanks for the replies guys....looks like another messy project.
Old 07-28-2008, 06:04 PM
G_T's Avatar
G_T G_T is offline
Default Two more ways
You can bruch on adhesive remover - you can buy that from home depot by the gallon. Just let it set for a while and scrape it off. Nasty mess.
If you have it on a rotisserie, then I'd suggest renting a power steam cleaner/washer. You can just blast away the undercoating/etc. works really well
1970 Dodge Charger: Viper Gen III V10/6spd, RMS Alterkation, Moser 60, 4x14" Wilwoods, RMS Street-Lynx triangulated four link. Currently mocking up...
Old 12-16-2008, 09:17 PM
69NBC's Avatar
69NBC 69NBC is offline
Just tried a propane weed burner and plastic paint scrapers. Scraped off like Butter! The scraper eventually lost its edge due to heat so it requires 2 or 3 per wheel well. Finished one well in less than an hour. Best of all the the debris got hard again right away and swept right into a dust pan.
Old 12-17-2008, 04:19 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I use an air hammer with a flat edge. Chipped right off.
Got the hard to reach areas with a wire wheel.
Old 12-17-2008, 06:32 PM
tazzz2_ca's Avatar
tazzz2_ca tazzz2_ca is offline
They say this tool cuts through it like butter and is great......I haven't personally used one but I am considering the purchase of one for my cars......
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old 12-18-2008, 05:53 AM
MarkM66's Avatar
After just finishing mine, I'll never not have it blasted off again. It takes to much time and is a total PITA, no matter how you do it yourself.
