Old 12-14-2004, 08:14 PM
Novacane Novacane is offline
Default What brakes are you running??
Getting ready to get the brake system together. 6 months ago as I put the plan together I intended to use a Wilwood setup. It comprised of a 6 piston Superlite (C5) setup up front and the 4 piston dynolite rears. This all combined with a manual master cylinder. I think it's the way to go but want to make sure I explore all of the options. What are some of you guys using on you PT rides??
Howard
62' Chevy 2, 427 ci twin turbo, 4L80E, Ford 9", AME 2" x 4" frame w/C5 front end......
www.redline-motorsports.net
2010 ZL1 Camaro (10.22@139)
06' Twin Turbo Charged ZO6 (1050/890) 8 second street car
Howard Tanner
Old 12-14-2004, 08:17 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I went with the typical Baer setup. 13" Track front, 12" touring rear with Eradispeed 2 piece rotors. What takes this setup completely over the top is the Hydroboost. The brakes are insane.
My LS7 69 Camaro
Old 12-14-2004, 08:23 PM
camcojb camcojb is online now
I went with the Baer Alcons (4 piston) up front with 13.25" Eradispeeds and rear PBR's with 13 1/8" Eradispeeds. I also am using Hydroboost.
The only thing that swayed me from Wilwood was the rear brakes. I love their front 6 piston units but they have nothing comparable in the rear. I was not impressed with my last Dynalite calipers.
Well that, and getting a ride in the Thrasher with those Alcons; flat out awesome braking.
Old 12-14-2004, 09:19 PM
Right now my car is using the factory style front disc and rear drum but i plan on doing it on a budget and using the touringclassics.com setup for the hybrid C5 setup front and rear.
William
Old 12-15-2004, 11:50 AM
ProTouringNyC's Avatar
ProTouringNyC ProTouringNyC is offline
I did the same as XcYZ Baer brakes and hydra-boost stops on a dime
Old 12-16-2004, 03:14 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
I did the 6 piston Wilwood set up with 13.25 inch rotors in front, 4 pistons big rotors in back. I went with the non emergency brake rears as I could get bigger (12 inch +) rotors for the back. I also have a yoke mounted EBrake (Looks like a disc brake set up) with the floor handle mounted on the hump. Also did the Hydro boost set up. Do spend your money on that great product.
I wanted to do the Alcons but MAN!! I did not want to have to get a second mortgage on the tractor to get em. They are sweet, but E X pensive!!
Jim
Old 12-16-2004, 03:18 PM
jonny51 jonny51 is offline
The tractor LMAO
Old 12-29-2004, 07:45 PM
lil427z's Avatar
lil427z lil427z is offline
Thumbs up
I am running the wilwood 13'' rotors drilled - sloted on all four conners with
4 pistons calapers with hydroboost . stops / stops/ stops .
rick kirkindall
Old 12-30-2004, 12:09 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
I did the budget thing and used C4 brakes all around with a S10 Mc. Hydroboost is in the plans.
For details check my homepage.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 01-03-2005, 08:46 PM
I don't have any room for a Hydraboost unit. The guys at Wilwood said it was not needed with a well designed 6 piston/4 piston setup. I would like to investigate the Alcons.....
Howard Tanner
