Old 08-28-2008, 07:18 AM
I found out the problem. I pulled my tank to do some re plumbing and called Hector. They design the tank so the sender is farther off the floor than it probably should be. I had 4 gallons in mine when I drained it and pegged on empty. I checked the sender with my ohmeter and it works fine. I bet what's happening is once you get down to around 5 gallons the float isn't submerged and the sloshing fuel is having a field day with your gauge and soon to be our gauges.
Old 08-28-2008, 07:22 AM
68protouring454's Avatar
if they know this, why no install a longer sending unit?
Jake's Rod Shop
Old 08-28-2008, 09:54 AM
My understanding is it was the advice of the manufacturer of the sending unit. Not thrilled with it really. I guess I'll have a 4-5 gallon reserve. That should get me atleast 50 miles. haha
Old 08-28-2008, 11:20 AM
holschen's Avatar
holschen holschen is offline
Default dont know if this helps
http://www.hoffmann-speedster.com/us/prod/VDO_2.asp
scroll down to 2/3 to find
CONSTANT REGULATOR FOR FUEL GAUGE
but i quess itīs the same function as the capasitator....
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 08-28-2008, 11:45 AM
Well it looks like the senders are made specifically for Ricks. They recommend 1 inch minimum clearance. http://www.wemausa.com/specifications/ssidweb.htm Mine is 1.25. She said they could make me one from scratch but it would cost out the nose. It would need to be 6.5 inches. It's understandable to need some clearance but over an inch seems like alot. Especially since the float is is really about 1.75 inches off the floor since the clearance is measured from the bottom of the collar.
Old 08-28-2008, 02:22 PM
DRJDVM's '69's Avatar
If you find a solution, let me know because its really annoying....
Mine moves around worse when its low but even 3/4-1/2 tank it still varies alot...
Old 08-28-2008, 07:35 AM
XcYZ's Avatar
XcYZ XcYZ is offline
That won't bother the gauge, but it is annoying.
Jake, I'm guessing that the design that they are using only comes in certain pre-made lengths. It's a floating collar style sending unit, so it's not something that can be modified like and old school setup with the float on an arm. Maybe one solution would be to place the sending unit in a different part of the tank that is deeper/taller?
My LS7 69 Camaro
Old 08-28-2008, 08:01 AM
scott, yeah fuel senders suck,lol
i know they make adjustable ones for fuel cells, similar to what they use, generally they have 8-12 ones and 10-14 inch ones, etc
Jake's Rod Shop
