Old 10-02-2008, 11:57 AM
Originally Posted by Mikamaro View Post
Alright Gents, Building my BBC up now.... has anybody fit a victor jr on a BBC under an original GM style cowl hood? Talking to tech while ordering my cylinder heads suggested I ditch my current manifold and go w/ the V jr. I like my cowl hood, don't want a fiberglass 4 incher, though bad-a$$, I like the style of the original.
Thanks,
Mike
you won't get a decent air filter on there, but the manifold and carb will clear. I used a Vic Jr with a big block 69 and had it converted to EFI. The throttle body is 1" shorter than a carb, and I still could only fit a 2.6-2.7" drop base 14" filter up top with the factory cowl. With a carb it would have been even worse, as it's 1" taller than my throttle body was.
Old 10-02-2008, 01:05 PM
68protouring454's Avatar
we got a 4 inch air cleaner on vinnys 68 camaro with a 496 and dart single plane intake which i believe is as tall or taller then the victors
Jake's Rod Shop
Old 10-02-2008, 02:17 PM
I'd love to know your secret.................... I did finally get a 3" drop base on there but I had to mill the carb pad down 3/8-1/2" or so, basically as far as it could be taken. Again, this was with a throttle body, much shorter than a carb. I'm not positive if this is the Holley intake or the Edelbrock, but the idea's the same.
Old 10-02-2008, 02:37 PM
i will get you a pic, its a drop base, no carb spacer, way more of a drop base then you have on that motor.
Jake's Rod Shop
Old 10-02-2008, 02:38 PM
Cread01 Cread01 is offline
I dont know what year car you have but on my 78 there is no way to keep a stock hood. I have a 4 inch hood but I also have a nitrous plate under the carb. I could see a 2 inch cowl but that would be with a low air cleaner.
Old 10-02-2008, 03:13 PM
*rayman*'s Avatar
*rayman* *rayman* is offline
I've just put a Team-G single plane on my 454 in a 68 camaro. With carby sitting on it I have just come over the line of the front fender. I dont have the hood on at the moment, so I will find out just how much clearance i have then i suppose... I'm planning to run a 14" drop base element, but may need to reconsider and go with a 9".
Pretty sure the Team-G is a fraction shorter than the victor jnr though.
68 BB SS Camaro - building it in Australia, where everything costs twice as much as it costs in the U.S.
Fuel prices suck!
Old 10-02-2008, 05:43 PM
gmjj13 gmjj13 is offline
496 BBC dart intake with 14" drop base and stock cowl hood
Old 10-02-2008, 07:18 PM
Mikamaro's Avatar
Mikamaro Mikamaro is offline
Thanks for the reply guys. I know the vic jr has the a/b measurement of 5.90". Dart lists the height of their intake at 6.25" tall. What allows it to fit in one car and not the other? Jody, did your ride happen to have shorter/lowering body mount bushings that would allow the engine to sit higher relative to the body? I have a CA chassisworks subframe w/ poly mounts, I think it keeps the engine at stock height compared to the body.
Old 10-02-2008, 07:21 PM
Efi69Cam Efi69Cam is offline
I have a Vic Jr with a Fast 1200CFM TB on my standard deck 540. Professional Products makes a spun aluminum dropped base that allowed me a 4.5" filter. This is even with their 1" spacer to clear the throttle linkage and fuel rails.
There is enough room under the cowl hood for 1/2" of clearance over the K&N filter lid.
It can be done.
