Old 09-04-2005, 11:36 AM
Steve Chryssos's Avatar
And more searching turned up an HKS Sequential that seems to be made by Hollinger.
________________
Steve Chryssos
Ridetech.com
Old 09-04-2005, 12:52 PM
DCreations DCreations is offline
That is a cool trans. So with a trans like that you don't need to use a clutch? or just for take off?
Steve could you use a paddle shifter with something like that?
Dave
“Tony Tony Tony, I know that your horny, but there’s
somethin bout that Bush ain’t right”
Old 09-04-2005, 06:11 PM
The inline shift pattern means that you absolutely could. Simple robotics could be built to control shift changes. And a simple micro controller could be built for downshift prevention based on vehicle speed/rpm inputs. As long as you are not trying to electronically control both shifting annd clutch operation clutch (as with trying to adapt the afrementioned Aston Martin system), the project becomes way more realistic--Challenging and expensive, but realistic.
/Steevo
________________
Steve Chryssos
Ridetech.com
Old 09-07-2005, 12:33 PM
That's good news in my world!!!!
Dave
