Old 12-31-2008, 07:06 PM
slck6t9's Avatar
slck6t9 slck6t9 is offline
Default Sound deadner
I am getting ready to order some B-Quiet sound deadner. I was wondering which I should order their Extreme or Ultimate? I noticed one is asphalt based and the other is butyl based. Is there advantage to either? Also there is a big price difference between the two. Thoughts please..
Old 12-31-2008, 07:21 PM
jst8a5.0's Avatar
jst8a5.0 jst8a5.0 is offline
DYNAMAT extreme 1 car kit and 2 door kits, not the cheapest stuff but the best from what I've seen. What I really like about it is that even when it's cold outside, it's still pliable, which means it's still working. Dynamat is not equal to roof shingles, water heater insulation, stuff at walmart, rubber mat,anything from the roofing section at Home Depot, anything at Pep Boys, jute padding, old t shirts, newspaper, undercoating from a can, bedliner, or any other short cut. You do this before you carpet, before running speaker wires but after mounting the seats and console. install after so you can dynamat around the mounts. Also, get yourself a wood roller or something like it. Smash that stuff in all the crevices and ruts in the floorboards. If you simply pat it down it's not doing it's job because it's not installed correctly. Every inch of that stuff needs to make contact with whatever you are covering. Otherwise you have wasted money. Good news is you can always go back and smash it in further, but a waste of time since you have to pull carpet and seats. Also, on the seams where the sticky backing is exposed, use the aluminum tape over it so you don't get that stuff on the knees of your pants.
Micah Prudhomme
Concept Fabrication, LLC
Shop page:
http://www.facebook.com/ConceptFab2006
Shop channel: https://www.youtube.com/my_videos
Old 01-26-2009, 03:46 PM
MIImaster MIImaster is offline
you should lean toward butyl based.
raamaudio.com is another alternate for product...
Rob
Old 01-26-2009, 03:56 PM
BBC69Camaro's Avatar
http://www.sounddeadenershowdown.com/
Old 01-26-2009, 06:08 PM
jst8a5.0's Avatar
Uhh, what about the most important test. What does is do for sound? I've used one of the other kind of sound deadeners and it was butyl based. In the cold it turned hard like plastic, hence no worky. My dynamat extreme didn't do that. I don't know. Dynamat has worked for me in the past. Even if it's the most expensive, so what? At most it's 500 bucks to do your entire car, forever. It's not like going with a subframe that winds up not performing like you wanted. Just a few buck compared to all the other equipment we have in our cars.
Micah Prudhomme
Shop page:
