Old 01-07-2009, 04:42 PM
deuce_454's Avatar
as a performance head they arent super... you might be able to find a "numbers matching" guy that needs just that very head on his chevelle or corvette.... in which case they are worth well 1500-2000 isnt to unthinkable if the date code is right too, but outright anywhere from 500-1000 on ebay or racingjunk....
but try a high reserve auction on ebay and see what happens..
i might be interested in them as well :-)
if you want to install them on your own car, id say no (unless you HAVE to have that date code on your tripower 69 corvette) .... its either alot of angle milling to unshroud valves and subseqent porting.. and then it will still suck on the street compared to almost and aftermarket BBC head... a pair of AFR´s or Profilers.. even RHS heads will outperfoem them by 80-100 Hp and be more streetable
Jake: Hit it.
