Old 02-04-2009, 06:20 PM
KEISLER's Avatar
KEISLER KEISLER is offline
Default T56 behind BOP engines
We have kits to do this for Chevy and BOP engines. You can use stock mechanical linkage or run our hydraulic kit for 20-25% pedal effort.
We can do this for new and used T56 units, and carry brand new aluminum bells for both Chevy and BOP. We remanufacture T56 in-house, and upgrade them at the same time. This is the least cost approach.
PM or email us for details, price, etc.
Shafi
Old 03-02-2009, 04:09 PM
462-6spd 462-6spd is offline
New guy to this site! Yes I have a T-56 behind a Pontiac. I got mine from D&D performance, it has an adapter plate that allows it to bolt directly to the stock bellhousing, it also uses the stock clutch & linkage, even uses the stock speedometer cable.
This is in a '79 Trans-Am, it was originally a 400-4spd. It is now bored & stroked to 462 and produced 495 HP & 563 FT-LB on an engine dyno. And yes, I do get a lot of engine braking!!
Old 03-06-2009, 08:40 PM
10Seconds's Avatar
10Seconds 10Seconds is offline
I did this too on a 455. I used the McLeod bellhousing piece, and the hydraulics. I never dyno'd it but I am guessing that its somewhere around 500hp/550ftlb.
