Old 02-04-2009, 06:35 PM
66LS7's Avatar
66LS7 66LS7 is offline
Default Heidts connectors
I am using the Heidts connectors on Re-Peeled my 70 Camaro project. They are closer to the floor than the competition ones & are not as tall.
Randy(D&Z Customs LLC.)1-262-347-9741
Old 02-04-2009, 11:35 PM
mazspeed's Avatar
mazspeed mazspeed is offline
I had the Competition Engineering, they were ok, they did hang too low, but really did help the car stiffness wise. The DSE's were the ones that made the huge difference.
Old 02-05-2009, 10:29 AM
thedude327 thedude327 is offline
Randy,
Could you post some pictures of the subframe connectors on your car to give an idea of how they look installed ?
Paul
1973 Z28 Street-touring project.........
Old 02-05-2009, 07:30 PM
66LS7's Avatar
I will see what I can do.
Randy(D&Z Customs LLC.) 1-262-347-9741
Old 02-06-2009, 08:59 AM
Heidts#14 Heidts#14 is offline
hold that thought Randy...........
Getting pics up asap
Old 02-06-2009, 11:01 AM
Lets try this one
Old 02-06-2009, 01:37 PM
Thanks for posting the pic of the subframe connector install. Seeing it gave me another question though. The mounting bolts at the rear of the connector that go up into the rear frame rail, are they going through existing holes in the rear rail section or drilled through the rail and up into the floor ? Oh and do you have some side profile shots with the car on the hoist ?
Thanks for any help with this.
Paul
Old 02-06-2009, 02:18 PM
In the 2nd gen frames there are actually existing holes that you feed a U bolt through that holds the bracket to the frame. I will get some more pics up asap
