Old 02-05-2009, 07:29 AM
almcbri's Avatar
almcbri almcbri is offline
Where is the front fender bolt holes on the firewall? I dig the firewall
Originally Posted by Steve1968LS2 View Post
The LS2 doesn't protrude into the tunnel area. You should only have to modify the tunnel if your particular subrame pushes certain transmissions too high.
I hope that made sense, it's hard to explain. We only had a fab a small part to mate the tunnel to the new firewall, but it didn't raise the tunnel at all.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 02-05-2009, 08:04 AM
Steve1968LS2's Avatar
Hadn't punched them in yet.. sorta forgot
They are now proudly present.
We also need to put in holes for the AC bulkheads and wiring.
I works pretty good and seems easier than patch working it flat. The story will be in the May issue of CP. Let me know if you need more info sooner.
Old 02-05-2009, 10:27 AM
street3285 street3285 is offline
Did you guys just weld up a sheet over the original firewall? Or did you cut out the old one in certain areas?
Old 02-15-2009, 06:18 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Hey, I just had Best of Show make a firewall for my 69 right after they did the one for Steve's Track Rat. They cut out all of the old firewall and replaced it with a with a piece of sheet metal cut from a cardboard/foamcore like template. Here are some pics they took.
There's the old one:
and the new one.
Matt
Old 02-15-2009, 07:16 PM
Yea, I showed up there right after you left... looked great!
What's funny is that BOS had a run on doing these with FOUR cars in the shop getting it done. They said it was a like a smooth firewall assembley line.
Your firewall certainly looks cleaner now compared to what the other shop did.
Old 02-15-2009, 07:18 PM
Most of the old firewall is still there. Any areas the "stuck out" were cut away. There will be a complete story in the May issue of Camaro Performers.
Old 02-16-2009, 12:29 AM
Matt@BOS's Avatar
Hmm...didn't know that. I never did look at the car from the inside. I suppose I'm just gonna have to wait for the new Camaro Performers issue to see exactly how those guys replaced everything. Its going to be like a closely guarded secret finally being revealed...well not really.
Oh and did D!ck ever get a shot to line up all of the smoothed firewalls side by side in various stages of completion?
Matt
Old 12-05-2009, 02:11 PM
nkopper nkopper is offline
Default re: Smooth firewall questions
I know this is resurrecting an old thread, but I've got a few questions about the smooth firewall BOS created for the Track Rat. In the Camaro Performers article, it looked like the master cylinder and steering column mounts were left intact, but they stick out about 1/8"-1/4", which would cause a bulge in the flat smoothing panel. Was this area cut out before the new panel was installed? Also, since the throttle pedal mount was cut off, how is the throttle pedal mounted?
Another question is about the wheelwell support braces. I like the complete smooth look without the braces, but what are the implications of not using the braces? The wheelwell seems a little flimsy without the braces attached.
Thanks,
Nathan
Old 12-05-2009, 02:27 PM
Bakaruda's Avatar
Bakaruda Bakaruda is offline
[IMG][/IMG]
[IMG][/IMG]
Here is mine just not completed yet.
