Old 02-05-2009, 12:28 PM
KEISLER's Avatar
KEISLER KEISLER is offline
Originally Posted by reboot04 View Post
Yeah... thanks
And now back to something that's actually relevant/applicable...
(sorry pet peeve)
I'm still waiting for the replacment TOB (should be here tomorrow) but, following Andrew's advice, I picked up a proper Quartermaster machined alignment tool. More annoying than self serving tripe is the useless alignment tool that McLeod ships with thir clutch...
James, that is a lame reply to someone trying to help you. On the Pro-Touring.com website, I responded to your same call for help on the same issue here. Since my post above was unclear, I'll post some more information that should be a little more relevant:
First, here is the response I posted on P-T:
"James, I have not read all of these post replies, but I can tell you that if your numbers are correct then you are constantly engaging the clutch fingers and it would be a wonder the clutch is not burned up.
If the 2.25inch number is correct, you need to reshim the bearing to 2.10 - 2.0inch compressed and not any more. You can see my comments about why on the other thread mentioned with the Pontiac guy with the Weir bellhousing.
If you hit a wall on this, PM me and we'll help you further."
It's clear to me - with the experience of selling more than several hundred of the same McLeod bearing you are using, and more than a couple hundred McLeod Street Twin just like you are prematurely toasting - that either the wrong bearing piston size was sent (bolt-on design) or you installed it wrong (slip on design). Either way the instructions that came with the product *should* have provided you with adequate information to prevent this problem.
Next, you can set up the bearing however you'd like, but I will tell you what you *should* do if you don't want to continue ruining the clutch:
1. maintain .150 +.05 / -.03 clearance from the fingers of your clutch to the face of the bearing in the compressed state
2.A) if you are using the McLeod slip on type, LOCKTITE BLUE the thread in sleeve so it doesnt' back in or out, because it will likely change position if you don't
2.B) if you are using the McLeod bolt on type, the pistons are numbered 1-8, and they increment in .200 inch. So you will will need to determine which piston change by the amount of interference or air gap. You can't do this with the unit apart as you are trying to do.
3. pre-bleed the entire system, then install it to the car and final bleed it
4. if you did everything above correctly, AND you have the correct master cylinder bore and stroke AND you have connected it to the pedal at the correct location to achieve the correct throw WITHOUT bottoming out the master cylinder before landing the pedal on the floor THEN the clutch should release at 1/3 to 1/2 of pedal travel. IF it releases at the top of the pedal, then you need to go back to square one and recheck you numbers.
A couple other tips for the McLeod hydr bearing - both slip on and bolt on:
1. if it comes with banjo joints, throw them away and make hard lines. You can get the inverted flare seat fitting with the correct male side to screw in from most any good hydraulic store
2. get a couple spare sets of o-ring kits from them 'cause you will need it and you don't want to be stuck without one. They used to send a spare oring set with the unit just for this purpose.
3. run DOT4 fluid
Good luck
