Old 02-09-2009, 07:15 PM
Pantera EFI Pantera EFI is offline
Default L92 VVT into BBC
If there was a way to fit the L92 VVT into your BBC, then you could gain 100 HP.
You would need to fit/machine the camshaft, front cover, oil passages.
Then fit the L92 timing sprocket.
Some major work, though I have a plan.
Lance
Old 02-10-2009, 03:37 AM
Adam68 Adam68 is offline
Lance
Hi Lance,
Sorry for asking the question but what is a L92 VVT? There was a guy named Lance that built my engine from califonian street machine. Do you know him?
Old 02-10-2009, 07:19 AM
Originally Posted by Adam68 View Post
Hi Lance,
I think he's speaking about the variable valve timing setup.
Old 02-10-2009, 11:40 AM
peetsjunkie peetsjunkie is offline
Still on the fence ..... just found out fellow contractors I work with just got let go....Not sure I want to spend the 4k now....cr@p
Old 02-10-2009, 05:19 PM
Racehead Racehead is offline
Is 4k the price for the 1000 hp BBC kit ? I PM'd Prodigy for a price but haven't gotten a response ?
'71 RS/Z28
468 BBC
Richmond ROD 6 speed
etc .........
Old 02-10-2009, 06:28 PM
PMs are a horrible way to get quotes from me because I get so many PMs. Email always works best because I see that all day. Email me at [email protected]
Frank Serafine
Old 02-15-2009, 09:47 AM
Default Variable Valve Timing
Jody, your BS-3 should be able to command the L-92 VVT.
(Variable Valve Timing) soleniod.
I need more information about the shop, I'm also in
S. Calif.
I am working with Iker Marine on the BBC VVT front cover.
Howard Cams is helping me with the camshaft.
Lance
