Old 02-10-2009, 11:40 AM
peetsjunkie peetsjunkie is offline
Still on the fence ..... just found out fellow contractors I work with just got let go....Not sure I want to spend the 4k now....cr@p
Old 02-10-2009, 05:19 PM
Racehead Racehead is offline
Is 4k the price for the 1000 hp BBC kit ? I PM'd Prodigy for a price but haven't gotten a response ?
'71 RS/Z28
468 BBC
Richmond ROD 6 speed
etc .........
Old 02-10-2009, 06:28 PM
PMs are a horrible way to get quotes from me because I get so many PMs. Email always works best because I see that all day. Email me at [email protected]
Frank Serafine
Old 02-15-2009, 09:47 AM
Pantera EFI Pantera EFI is offline
Default Variable Valve Timing
Jody, your BS-3 should be able to command the L-92 VVT.
(Variable Valve Timing) soleniod.
I need more information about the shop, I'm also in
S. Calif.
I am working with Iker Marine on the BBC VVT front cover.
Howard Cams is helping me with the camshaft.
Lance
Old 02-23-2009, 04:43 PM
Well I pulled the trigger on the EFI today..... Thanks Frank...
Let's hope it's not a nightmare to install......Need to figure out how big of a hole to cut into my firewall now that it's all smoothed out.
Old 02-23-2009, 04:50 PM
S. Calif.
Lance
yeah, I think you're working with a good friend of mine to do that for his twin turbo LS2 (Troy). Should be the best of the best, I just can't afford it right now.
Old 02-23-2009, 04:51 PM
no nightmare, pretty basic really. You'll love it, Frank will take good care of you.
Old 02-23-2009, 10:51 PM
540 540 is offline
540 Fuel injected. Fast xfi video was second day of tunnig very rich, Rob rom Force Fuel did the final tune on the chasi dyno. Blew the left rear wheel at about 6600 rpm. AUCH We did the install very straight foward do not let all the wires scare you.
http://www.fquick.com/videos/viewvideo.php?id=8076
Old 02-24-2009, 06:23 PM
You happen to know what size hole they require for the harness to come through the firewall? I might have to download the maneul.
