Old 03-01-2009, 08:01 PM
mwhizard's Avatar
mwhizard mwhizard is offline
Default what clutch master and line?
I've got a '71 camaro and am putting a '07 corvette ls2 with a '99 camaro t56 into it. Question is, what clutch master should I use? I didn't get the matching master for the t56 and have just realized that GM uses some rediculous quick disconnect hydraulic fitting that no-one else seems to make.
Any of you guys out there run into this issue? What did you do? Help?!?
Old 03-01-2009, 09:55 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
I am using the stock master out of my donor car. I know that ATS can help you if tyler is willing to mod one for you. Also Keisler my have something to help you out. just look left and find one of the great vendors on this site to help you out. hope this helps
Old 03-02-2009, 08:38 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Have you checked to see if McLeod make that adaptor fitting?
If you want to run a Wilwood mc, just get one that close to the bore size of the stock vette mc.
Old 03-06-2009, 09:41 PM
10Seconds's Avatar
10Seconds 10Seconds is offline
I got my hydraulics from McLeod, hooked up just fine.
Old 03-06-2009, 10:56 PM
mwhizard's Avatar
ordered my clutch line from speedwaymotors.com 22 inch steel braided line, $50. got the tool as well, $5. I think it is a mcleod part.
I have researched a clutch master cylinder that I think may work well. It's a stock replacement part for a '88 chevy corsica. 7/8 bore, nice flat 2 bolt flange to mount to the firewall, and remote resevoir. (plus it's only $29 brand new (raybestos part, ebay) what do you guys think?
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old 03-12-2009, 11:54 AM
KeislerJeff's Avatar
KeislerJeff KeislerJeff is offline
We have a complete kit that eliminates the factory release bearing. $599.95 + shipping and is engineered specifically for the 2nd gen Camaro.
Jeff Kauffman
Keisler Engineering Inc.
www.keisler.com
888-609-0070 ext. 210
[email protected]
Keisler...#1 selling overdrive kit!
Join newsletter
Request a quote
