Old 02-12-2009, 08:03 AM
bentfab's Avatar
bentfab bentfab is offline
Originally Posted by ironworks View Post
You know cardboard is lighter then steel.
So when are we going to cut out those rails?
Roger,
I told you to not let the cat out of the bag. Just don't tell anyone about my new welder that can weld the two together. Lincoln 250 Card-Board-O-Matic w/ pulse option.
I think these rails I'm cutting in-house. To simple !!
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 02-12-2009, 05:25 PM
Kendall Burleson Kendall Burleson is offline
Man I thought I was the only one who had one of those machine. Roger how much heat do you used on the green tape wire?
Old 03-10-2009, 05:55 PM
bentfab's Avatar
Finally a couple more pics. Got the pass. frame rail,exhaust cut out, and front arm pocket done. All this cause the customer wanted side exhaust. So I had to figure out how to make this thing into a brick house and still let the exhaust out the side.
Old 03-10-2009, 09:25 PM
customcam's Avatar
Very cool and Clean man Did you try to talk him out of the side exhaust?
Old 03-11-2009, 06:40 AM
city_ofthe_south's Avatar
city_ofthe_south city_ofthe_south is offline
niiiiiice. Gonna be a killer Cuda
www.odellstudios.com ... it's turned in to more than cars.
Old 03-11-2009, 07:45 AM
syborg tt's Avatar
Mark - looking really nice.
marty-mj
Old 03-11-2009, 08:16 AM
bentfab's Avatar
Yes and no. He thought of doing it like the original. If you have ever seen that you should be killed on the spot. So I showed him an option and went with it. I think it will look tits when finished. If you've seen the new Lexus 460 sedan rear exhaust it will use that concept and idea. The tips will have the same contour as the body panel and sit flush. It'll be pretty trick !!
Old 03-11-2009, 09:08 AM
ironworks's Avatar
That is real nice work bench decoration in the back ground of the first pic. In 2 months I would have thought you might have gotten farther then that.
Come on buddy.
Old 03-11-2009, 10:25 AM
bentfab's Avatar
Come on buddy.
It's called employees O' Great one. If you can't find good help you can't get stuff done. I finally found one and he started last week. THANK GOD !!!! So progress is going to be good.
Besides I like work bench decorations!!
Old 03-11-2009, 02:00 PM
HWY Nova HWY Nova is offline
Hell, I thought Mark was trying to make the Truck frame-clip fit into the Cuda!
--Eric
ET
62 Nova Coupe
62 Nova Convertible @ Ironworks Speed & Kustom
