Old 03-17-2009, 09:37 AM
Steve Chryssos's Avatar
Massaging, if any is as simple as heating up the area with a propane torch and tweaking with a hammer. A few love taps is all that is usually required. Stock subframes usually do not require mods. Aftermarket subs usually raise the engine a bit to make steering rack clearance. In that case, the tunnel might need tweaking right where it meets the firewall. We have a big block/4L80E/stock clip car with no tweaking.
________________
Steve Chryssos
Ridetech.com
Old 03-17-2009, 01:03 PM
Neki67 Neki67 is offline
Same here! Don't worry, it's tight but it'll fit.
Old 03-17-2009, 08:37 PM
Roblee67 Roblee67 is offline
I am using the Heidts front sub frame ...do you know if I will have to modify the tunnel or will it fit??
Robert Lee
1968 RS Camaro
2001 SS Camaro
Old 03-18-2009, 07:53 AM
Sorry, we have not tried a Heidt's clip. You will need to contact them directly. Ask if they have raised the motor mount position to compensate for steering rack to engine (harmonic damper) clearance.
________________
Steve Chryssos
Ridetech.com
Old 03-18-2009, 09:10 AM
Thanks, I,ll give them a call..
Robert Lee
1968 RS Camaro
2001 SS Camaro
