Old 03-23-2009, 04:51 PM
rogue rogue is offline
Default Camaro w hotchkis leafs - one wheel off the ground in a driveway?
Quick question for you all.
I'm running Hotchkis subframe connectors, rear lowering leafs and QA1 shocks dialed to the softest setting.
When I pull into a semi-steep driveway at an angle one rear wheel will lift up off the ground and spin a bit. Is this normal for a camaro with a properly stiff chassis or are my leafs not installed correctly. Yes I do have posi.
The rear suspension does seem pretty stiff on the highway, not rock hard but definitely firm. Car does great on the track so maybe its normal?
Just a random thought I figured I'd ask about.
Old 03-23-2009, 05:41 PM
Steve1968LS2's Avatar
did you tighten down the shakles with the car up on a lift? If so they might be in bind.
With the weight on the wheels loosen the shackles and re-tighten them with the suspension loaded.
Just an idea.
Old 03-23-2009, 06:27 PM
mpozziCPL mpozziCPL is offline
Yes, pretty much normal ...
Cheers,
Mary Pozzi
Old 03-23-2009, 06:40 PM
Cheers,
Mary Pozzi
You guys with your wacky leaf springs...
Old 03-24-2009, 10:03 AM
Better watch it, Mary might have to start making Penny look bad with those leaf springs of hers
Cheers,
Mary Pozzi
Old 03-24-2009, 04:30 PM
Mary could make me look bad in a Yugo.. lol
Her time at the Costa Mesa autocross was tied for best old car with the DSE second gen.
