Old 04-21-2009, 03:20 PM
hifi875's Avatar
hifi875 hifi875 is offline
Default coys/c5 brakes
there will be no clearance issue atleast w/18's
Old 04-21-2009, 05:27 PM
68FBODY 68FBODY is offline
I was planning on making my own kit for my car. Buying the brackets separate, and then buying some c4 13" rotors, already have c5 calipers,
1968 Firebird Pro-Touring project
1967 Mustang Fastback Pro-Touring project
Old 04-21-2009, 06:46 PM
z11 z11 is offline
I have a ZO6 set up from KORE3 and 18" Coys C5s.
Old 04-21-2009, 08:04 PM
Beautiful car btw! I have 17" coys
Old 04-21-2009, 10:17 PM
WILWAXU WILWAXU is offline
Kore will sell you separate or a whole kit. Give then a call. They'll help out.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 04-22-2009, 03:50 AM
camaropower68 camaropower68 is offline
If your planning on running the 13" c4 rotor you will be more then fine. That's exactly what I had in my picture. They're actually able to clear a 17" Torq Thurst II wheel with the raised corvette lettering shaved off. Touring classics will also be able to sell you the brackets for this hybrid c4/c5 setup. I have used both Touring Classics and Kore3 brackets and I am pleased with both company's products.
Old 04-22-2009, 07:55 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Are you concerend with Caliper face to wheel clearance?
If so, ask Coy how thick their wheel pad is, and then measure how far your caliper is past the wheel mounting surface/rotor face. Which I believe will be right around 3/4"
