Old 05-08-2009, 09:19 AM
GM Muscle's Avatar
Default 4l60e
i have access to a fully built 4l60e out of an ls1 style camaro. i can get this thing with the 3600 yank converter for a smooth grand. i know that i will have to get a controller to control the transmission buy my main question is what will i have to do to get this to bolt up to my early small block? is there an adaptor plate or spacer? what problems am i going to run into trying to mate this ls1 trans to my early model sbc?
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 05-08-2009, 10:55 AM
patriot68 patriot68 is online now
i dont think it will work. the ls1 4l60e converter is bigger than the earlier ones. will probably be to tight
1968 Camaro, LS1/T56,martz chassis,19x10/18x8 Budniks,245/45/18,295/35/19 {Sold}
http://www.fquick.com/patriot68
1971 Firebird - Speedtech Extreme Subframe/Torque Arm, LS3/4L80E, 19x12/18x10 Budniks
Old 05-08-2009, 10:58 AM
tjbruning tjbruning is offline
Call up Ross at Quicktime. They make bellhousings for the 4l60e auto...
http://www.quicktimeinc.com
Old 05-10-2009, 08:39 AM
GM Muscle's Avatar
can anyone confirm this
Old 05-11-2009, 04:34 PM
Steve Chryssos's Avatar
Sounds like a steal. You are way ahead of the game. Bellhousing is fine. But you will need a different converter. Shouldn't be too hard to sell that 3600 converter. That's too much stall for a pro-touring car anyway. Confirm the year of transmission. If you cannot confirm, give me a call and I'll talk you thru identifying your transmission input shaft. With the transmission side handled, the torque converter's front cover needs to match your gen 1 engine. That's the best way to get the job done.
We can build a converter to match your exact requirements.
/Steve
________________
Steve Chryssos
Ridetech.com
