Old 05-15-2009, 04:56 AM
2Bad4Ya's Avatar
2Bad4Ya 2Bad4Ya is offline
Default Valve Cover Clearance
I have a problem, I ordered the GM Performance 12480127 valve covers to go on my 327 w/roller rockers, and of course the baffle seems to hit the rockers. Even with the rocker horizontal and neither end at the apex of its lift the cover looks about 2 inches too short.
I thought about grinding off the baffle, but then if I install grommet and push a breather into the opening the breather would possibly hit the rocker, no?
The problem is GM does not make this valve cover in a tall version and have the same finish, the tall ones all seem to be powder coated. I was trying to keep the engine looking black, and aluminum.
Any suggestions on how to proceed, or ideas for valve covers would help, thanx!
http://www.FQUICK.com/2Bad4Ya
Old 05-15-2009, 05:19 AM
2Bad4Ya's Avatar
well guess I did not look hard enough. There is a tall version that looks like the short version. The images I found online of the tall one did not look like right, but according to my local shop they are the same, just with no oil/pcv holes.
He also said the short and tall version are only 1 inch different, and if I had the short ones just run spacers... Anyone else running the short covers with roller rockers, and if so how did you do it?
Old 05-15-2009, 06:03 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I've heard of people running two gaskets to gain a little more clearance. I also believe there are thicker gaskets.
May work if you're close.
You could always just run stock rockers.
Old 05-17-2009, 08:17 AM
thedude327 thedude327 is offline
Here's a spacer kit that will allow you to use the valve covers you already bought. $55.00 plus shipping. PM me if interested.
Paul
1973 Z28 Street-touring project.........
Old 05-17-2009, 11:55 AM
2Bad4Ya's Avatar
We decided to just return them instead of buying spacers, and get some new tll ones.
Old 05-18-2009, 02:17 PM
mike23109 mike23109 is offline
When you get the tall ones you have to drill your own holes for the oil fill/PCV. I've tried several different types of rubber baffles/grommets and none of them are worth a damn. Summit offers a screw in aluminum baffle that has worked fine for me. Good luck! Mike
Old 05-18-2009, 04:05 PM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
I have the big block version of those covers. I had to drill my own PCV holes and I used a Moroso baffled rubber grommet(Summit part # MOR-68775) for the hole openings. The grommet leaked slightly at first so I pulled it out and put some black RTV high-temp silicone in the groove of the grommet, re-installed, wiped off any excess, and it's been leak-free ever since. Just be sure not to drill the holes too large. Drill it slightly too small and then slowly enlarge it with a metal file until you get a tight fit. I also found that the following Fel Pro gaskets worked beautiful with these covers:
Summit Part # FPP-1635. They re-seal wonderfully and look a little better than the cork. I think they're worth the extra money.
Good luck with your covers!
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
