Old 05-23-2009, 08:06 AM
NvrDun71 NvrDun71 is offline
Originally Posted by ohcbird View Post
OK- I've had several PMs about the DSE box & ATS spindles; the DSE box & rag joint (with fittings) are 525 + 75 respectively. The ATS short spindles are $600. First one to get me $$$ gets them.
Another PM Sent....
71' Nova - LY6, T56
Old 05-23-2009, 04:26 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Default PMs
PMs replied to.
Old 05-23-2009, 04:59 PM
lsb's Avatar
lsb lsb is offline
Jess-
If no one wants the box with the sub, I'll let it go for $525. Rag joint + fittings will run an extra $75.
lsb-
I'll take some pics, but be warned- right now it's just a painted frame with the UCAs/LCAs taken off to protect them. What exactly are you interested in, the frame without any 'options'?
is the dse box smaller than stock one? also does frame have any damage? I am looking for a nice piece for my 68 firebird!
Old 05-23-2009, 08:13 PM
ohcbird's Avatar
Default Sub
The DSE box is about the same size as the stock box, but it does appear to be slightly smaller... negligible at best.
There is no damage to the sub; it's been very well taken care of & detailed. Let me know what you're interested in.
Old 05-24-2009, 08:05 AM
lsb's Avatar
lsb lsb is offline
I am interested in sub with rotors, calipers ,control arms ,coil over shocks ,sway bar ,drop spindals. also has frame been media blasted? I would like to see pics if possible i am ready to put something under this car. I was ready to buy a dse sub but i would rather have a real nice stock frame with dse hardware.
Old 05-24-2009, 12:04 PM
ohcbird's Avatar
The frame has been blasted & the welds have been reinforced. There is also a notch for an AC compressor should you choose to run an LS engine. I'll take some pics & get them to you later today (I'm still doing a bunch of wiring work).
Going through the list of what you want, I noticed you asked for drop spindles- I don't have those. I do have stock spindles and a Wilwood 6 piston kit that is designed for them. The sub with the Wilwoods and all the parts you asked for (with regular spindles), shipped to you (assuming you are in the lower 48) will be $4800. Let me know if you're serious, so we can get everything together to ship it out.
Jeff
PH# in a PM to you LSB...
Old 05-31-2009, 09:38 PM
ohcbird's Avatar
Default Sold Sold Sold
DSE sub & DSE parts (other than the steering box+it's parts) have been sold. I still have the unisteer kit.
Old 06-03-2009, 07:25 PM
meenaggie meenaggie is offline
PM sent on the DSE box.
Old 06-07-2009, 04:29 PM
lsb's Avatar
lsb lsb is offline
Smile
Thanks for the subframe!
