Old 07-19-2009, 04:11 PM
Formula400 Formula400 is offline
Hi Greg!
#H242 074 and #212138215 are the numbers on the driver side of the block just above the oil filter and I can't make heads or tales of it and nothing matches the linked stuff.
But thanks a lot for the link.
I'm thinking that it might be a replacement engine of some sort? but shouldn't it still say in the Engine vin that it was made by GM and it's a 5.7 liter engine.....
Hmm found something that might be what I'm looking for. ( http://forum.grrrr8.net/showthread.php?t=4617
Engine Serial Number 10H7A H07190001 is used as an example:
The first two digits, 10 identify the component ID.
The next three digits, H7A, identify the engine model.
The next digit, H, identifies the plant code as Holden.
The next two digits, 07, identify the engine model year as 2007.
The next three digits, 190, identify the Julian date the engine was manufactured as day 190.
The next four digits, 0011, identify the assembly plant sequence number as 0011.
#10YHB K010460431 so from this I get the following. (got these numbers from a sticker on both the driverside head and the block)
1. Component is 10 (might stand for petrol engine)
2. YHB now this is very interesting... what does YHB stand for?
3. Plant code K??? Is there a plant that GM owns that starts with a K?
4. 01 would make the engine a 2001 as several other clues has told me.
5. 046 would make it mid february or something.
//Sven
Respect is something you can DEMAND but it's really something you have to EARN.
It's much EASIER to blame your FAULTS on somebody else than to blame YOURSELF.
