Old 08-02-2009, 11:03 AM
ivmotor ivmotor is offline
Its funny how the technology moves.
If the lift is beyond the mechanical abilities of the rocker, they bind and break through eventually. The rocker that has the "ball-o-sludge" is due to lack of lubrication at some point. It got hot and the oil that made it to the rocker was baked in place. You need a good set of roller rockers or a set of long slot stamped rockers. Use cam lube on the pivot balls for the initial start-up.
