Old 08-26-2009, 07:35 PM
scherp69's Avatar
scherp69 scherp69 is offline
What about the 3.5? It's a dual friction clutch. I just want to get something that will handle any upgrades I decide to make to the motor.
http://www.monsterclutches.com/level35clutch.html
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 08-27-2009, 06:22 AM
J2SpeedandCustom J2SpeedandCustom is offline
My experience is once you start trying to make power over 500whp your going to want a multi-plate clutch. Single disks to hold the same power need a stronger pressure plate and more aggressive material. I've welded 3 different single disk puck style clutch disks to the pressure plate and flywheel. Plus driveablity is in the toilet, these single disks grab right now. They have to in order to hold power in upper rpms.
How high in "upgrades" are you going to go? 700, 800, 900, 1000whp?
Jeff Allen
J2 Speed and Custom
Old 09-04-2009, 02:41 PM
1 Dwn Cam's Avatar
1 Dwn Cam 1 Dwn Cam is offline
I would agree with "J2speedandcustom" the more power you make above 500hp the more aggresive the disc has to be and the greater the pressure has to be due to lack of surface area. I have a Mcleod Twin disc in my camaro and love it. Holds all the power I can throw at it and the pressure of a toyota.
This will give you an Idea.
http://www.cardomain.com/ride/2368130/1
Vrbancic Brothers Procharged 406
781.5 HP @ 6500
701 @ 5500
14 psi.
