Old 08-26-2009, 02:04 PM
syborg tt's Avatar
Originally Posted by The T-man View Post
if my main concern is price, ride quality/comfort, in other words
I'd like to avoide dropping the $2-3K and
have a smooth compliant ride and still be able to take some twisties once in awhile
So, that leaves me with DSE I would guess?
Well, If you go DSE depending on the part you choose you will quickly go over budget.
From what I can gather you are going to keep your stock from subframe.
So here is what I suggest - I think you can buy the entire Hotchkis kit for a second gen for about 2800.
That includes everything you need to get a nice ride height / stance with a comfortable ride.
ps - I forgot about Hotchkis, they are one of my favorites
marty-mj
Old 08-26-2009, 03:01 PM
71RS/SS396's Avatar
73 camaro, going to mini -tub it, and thought while we are under there,
G-bar or Quadralink ?
or the big question, is it "really" worth the time and $ for these to get a 335 rear tire? I hear stories of some people getting lucky and stuffing a 315 under some stock 70-73's, which I could be happy with and save the 2-3K$
any truth to that? rolling the fender lip or bashing in the wheel housing with a BFH is fine w/ me
The ride height and tire diameter will really determine how much tire you can fit under it,the wheel lip is not really the problem on 2nd gens, it's the outer wheel well if you get the car low because of the way it rolls back towards the center of the car. I have hotchkis springs on mine with 2" lowering blocks to lower the car a total of 3.5" running 275/40-18 on a 8" wheel w/ 4.75 backspacing and is really tight to the outer wheel well you might get away with a 9" wheel w/5.75 backspacing,because mine still has some room inside. there really isn't any room between the quarter panel and the outer wheel well to gain any tire clearance , if you start wailing with a hammer you will be fixing your quarter panel. The front is an even bigger pain in the arse to get any tire under it if you get the car low!!
Old 08-27-2009, 06:52 AM
I sell and install both. The Quadralink is great, requires a lot more labor, cutting, wleding to install. Also reauires a lot of welding on the rear housing, cutting ends off, rewelding, etc. The G Bar / Prodigy Bar is a great suspension also, rides good, handles well, and is easy to install and requires only minor welding on the rear end housing.
I do believe the 2nd gen Quadralink has a slight performance at the high end of the performance scale in a full on race application. But the Quadra Link will cost a lot more in materials, labor and time.
It is a ways off, but once a G Link is designed for second gens, I suspect any performance gap will be reduced.
Both will ride great and will handle and ride great. Can you do the cutting and welding? Or afford to pay to have it done. Then the choice is simple right now.
Frank Serafine
Old 08-31-2009, 10:56 AM
The T-man The T-man is offline
So you are saying Gbar then...
Old 09-02-2009, 08:35 AM
markss28 markss28 is offline
I have hotchkis springs all the way around on my 73 camaro. I have a 18x10 in back and an 18x8 in front. I have 285/35/18 tire and can go without rubbing a 295/35 tire. This to me looks great and handles very well. The front looks great too and does not rub even when I cut a whole coil off to get it to drop a bit more. I would buy the entire hotchkis stuff. complete bolt on no lie stuff.
Also I think Mari Pozzi runs this in her 2nd gen and she beats everybody.
Never Stay Stock
Old 09-02-2009, 09:23 AM
syborg tt's Avatar
Okay I would love to see pics of your car.
marty-mj
Old 09-03-2009, 08:43 AM
Coming soon to a website near you. Maybe this weekend.
Never Stay Stock
Old 09-03-2009, 09:11 AM
syborg tt's Avatar
send me the pics and I will build you a quick gallery on Garagescene.net
[email protected]
marty-mj
Old 09-04-2009, 10:28 AM
Marcus SC&C's Avatar
Taking things from a technical aspect with no fan coolaid involved, the Quadralink has excellent roll steer characteristics and a slightly more stable (vertically) roll center than the G-Bar. The G Bar is much easier to install, is less expensive, has better anti squat (easier to put power to the ground) and has two optional anti roll bars, including a 3 way adj. frame mounted one. This gives you many more tuning options and allows you to get hardcore wheel rates with more suple spring rates and a better ride. Both use rubber bushings, G Bar uses some poly g. also. The G Bar can be upgraded with SC&C billet double adj. arms with greasable forged Johnny Joints which are offset inboard for even more tire clearance, have better lateral axle location capabilities and save weight. They look cool too. Mark SC&C
