Old 09-14-2009, 11:01 AM
tukes23's Avatar
tukes23 tukes23 is offline
the bellhousing was sfi certified but the fly wheel was not. the only reason that the bellhousing didn't contain the flywheel when it let go was that the bolt holes in the block broke.
Old 09-14-2009, 11:29 AM
cees67's Avatar
cees67 cees67 is offline
thank god that everyone is ok .........and that motor "was" a beast!
Old 09-14-2009, 08:22 PM
nvr2fst nvr2fst is offline
From the photos it looks like you used standard bolts to mount block plate and bellhousing. Im also curious if you did the same to mount flywheel. Did somebody forget to torque bolts.
Old 09-14-2009, 08:26 PM
tukes23's Avatar
just for the record, we had nothing to do with this motor. we are building the car and doing everything else but the motor was built and dynoed by someone else. the video on the site was acutally taken by the owner of the car at the dyno facility in another state.
Old 09-15-2009, 05:37 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Damn. That's nasty.
My LS7 69 Camaro
Old 09-15-2009, 06:40 AM
ElkyZO6 ElkyZO6 is offline
Better there then in the car going down the road.
Old 09-15-2009, 03:56 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Just watching the video is bad enough! Can't imagine being there and having it happen. Glad everyone is o.k.!
Curtis
