Old 09-14-2009, 07:59 PM
JRouche JRouche is offline
Originally Posted by BBC71Nova View Post
Scott,
Did you have the Craftsman Professional wood/metal unit? The one I'm talking about is big. Comes in a 15" and 18" model. Floor standing setup. Below is excerpt from the 15" model description. I was thinking this slow speed would be acceptable?
...4 speeds: 2800 fpm for wood, 80/150/200 fpm for metal/plastics. 1-1/2 hp max. dev. motor, 115/230 volts. 14-5/8 in. throat capacity w/8-1/2 in. max depth cut/90 deg.
John
That looks like it might fit the bill. See if you can find out if it uses rubber tires on the wheels. If so that might be a problem. The lower blade speeds are just fine for metal. And really, the blade choice makes ALL the diff. Get a good Starrett or Morse blade and it will be nice. JR
