Old 09-24-2009, 09:52 PM
camaro2nv's Avatar
camaro2nv camaro2nv is offline
I've used the road force 'balance' system and have found "out of round" tires etc --- but that machine wouldn't keep the tires seated on the rims --- because you've already mounted the tire up. And that is where the problem is - the use of mounting soaps etc.... and then going out and hammering the combo.
I ran a wheel shop with this machine. The drum will come down and seat the bead on the rim. It will say "seating bead" on the screen. Once that is done it will stop the rim and spin it the other direction still on the drum. We did a LOT of high end cars and never once had a problem. Its really the best money can buy!
