Old 09-27-2009, 01:22 PM
av8or32 av8or32 is offline
Default pre dynamat coating?
What do people generally spray the floorpans etc with before laying down sound deadener?
Old 09-27-2009, 01:40 PM
kochevy67's Avatar
kochevy67 kochevy67 is offline
I used Rustoleum and I have seen POR 15 used as well.
Old 09-29-2009, 04:47 PM
sp68cvert sp68cvert is offline
I understand lizared skin is being used. I am going to use this.
Old 10-01-2009, 10:34 AM
the professional opinion seems to be epoxy.
Old 10-01-2009, 06:39 PM
JamesJ JamesJ is offline
If you are going to spray lizard skin then just do both and skip the dynamat, you can use it in some of the hard to reach places, thats what I did.
James J.
Old 10-01-2009, 07:24 PM
I already have a roll of raamat
Old 10-04-2009, 02:46 PM
hectore3 hectore3 is offline
I've gone with the complete POR-15 system and I was happy.
Old 01-01-2010, 04:11 PM
jwalk's Avatar
jwalk jwalk is offline
I used por-15 and it turned out pretty good.
Old 01-11-2010, 08:29 AM
HOLOHAN'S HOT ROD SHOP's Avatar
HOLOHAN'S HOT ROD SHOP HOLOHAN'S HOT ROD SHOP is offline
Epoxy primer always.....But if you were to use Lizard skin and Dynamat, I would put the dynamat first, ,spray some bulldog adhesive promoter on the dynamat then spary the lizardskin.
