  #27
Old 10-23-2009, 07:49 AM
JohnC JohnC is offline
I have chased this problem for years...
List of what I have learned
  • Roller bearing on a Ford 9 inch won't work for road racing.
    GM went to a stiffer front wheel bearing on the ZR1, STS-V and CTS-V to fix brake knock back.
    The bigger the rotors the bigger the problem.
    2 psi valves won't do it
The test I use is to do a figure eight in a parking lot at max lat then measure the brake pedel travel.
If you can't fix the problem learn how to left foot brake on the straights to pump up the brakes. I have done this for years.
Mark
Hi Mark,
Do you know the GM part number for the stiffer ZR1 front wheel bearing?
I want to make sure I have the right ones...
