Old 11-18-2009, 04:03 PM
Swain's Avatar
Swain Swain is offline
Default Ca Glink Install Pics Needed
I am installing my G Link on my 68 Camaro. Does anyone have photos of the install with a 9"?
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 11-18-2009, 04:13 PM
ironworks's Avatar
Check out the Chassisworks Camaro build, I have alot more pics, but they are for the magazine article in Musclecar Power. Let me know what you need.
Old 11-18-2009, 05:46 PM
Aschle's Avatar
Aschle Aschle is offline
Still down for making me a set of frame rails? I am the guy you spoke with at Pinks all out with the 69' Camaro... I have my car torn apart in the garage right now and the frame rails are going to be soon on the list...
Jason
Jason Aschle
________________
1969 Camaro
1957 Chevy 150 Utility sedan, semi-pro touring
2016 MB s-AMG E63
Old 11-18-2009, 06:23 PM
ironworks's Avatar
Yes Sir
Old 11-18-2009, 07:24 PM
markd's Avatar
markd markd is offline
How about these pics????
Good luck with the install!
Mark
Project 69 Camaro: DSE mini tubs, Chassisworks G-Bar and FAB-9 rear suspension, Chassisworks front sub-frame, 14” Wilwood brakes with 6 piston red calipers, 18" Fesler 905 Wheels, Fesler Billet, ISIS multiplier system, Vintage Air, Prodigy Cool Package, Ricks Tank, Turnkey LS3, 4L65e transmission and a lot of other cool stuff!
More pictures: http://camaro69vn10.com The Website is finally Updated!
https://lateral-g.net/forums/showthread.php4?t=13756
Old 11-18-2009, 07:32 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Mark,
Did you ever do any adjusting on the ride height?
Chris
Old 11-19-2009, 08:18 AM
Swain's Avatar
Does this sound right, My measurements mounting surface to mounting surface is 54.75"
Housing width 49.15
Driver Housing 19.189
Pass Housing 19.941
Driver Tube 15.162
Pass Tube 15.914
Pin offset 0.5
I had my currie built to these specs.
Jason Swain
Old 11-19-2009, 11:47 AM
Those measurements will work with a 5.4 BS on a 12" wheels Jay. but your overall width should only be 5" wider then your housing width (49.15 + 5 is 54.15" axle flange to axle flange)
Here is one we just went back home to California! This one has a 6" BS and a wider housing.
Frank Serafine
