Old 11-19-2009, 09:32 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Originally Posted by Ron Fox View Post
Thanks Mike and Greg. This is what this site is all about.
Please keep the information coming because I am trying to soak up all the car information I can.
Please talk more about the cause and solution of the bogging down issue with high hp.
Thanks.
What engine are you putting in the car, what heads, how big are the intake runners, how big a cam, what induction system and what transmission and rear gear are you going for? My guess is you don't need to worry about a bog off idle, but some info on your build might help.
Old 11-19-2009, 10:45 AM
I have owned a couple of Richmond 5 speeds, and driven several more. I would never buy one again when there's the TKO and T56's out there that are MUCH nicer shifting (my opinion) and give you overdrive. I also think $1400 is high for that trans.
My two cents.
Old 11-19-2009, 11:09 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
My two cents.
Please give me your pro's and con's on your TKO.
Thanks.
Ron
1969 Firebird, 4-speed Coupe
Old 11-19-2009, 11:17 AM
Thanks.
The TKO and T56 are stronger, smoother shifting, and both give you an overdrive gear (T56 has two). Really no comparison. When Doug Nash (now Richmond) came out with the 5 speed it's main benefit was less rpm drop between gears, and with the lower first gear ratio you could run a taller rear gear and lower your cruising rpms as compared to the factory Muncies.
But they just don't shift all that well, and since they do not have overdrive the TKO's and T56's are a much better alternative.
Old 11-19-2009, 11:55 AM
Ron Fox's Avatar
Is there an rpm drop with the TKO?
Ron
Old 11-19-2009, 12:12 PM
as compared to what? Compared to a Richmond 5 speed, yes, the TKO has an overdrive gear for fifth instead of the Richmonds 1:1 fifth gear. If you're cruising down the freeway at 70 mph with the Richmond and you're turning say 2800 rpms, you'll be between 1800-1900 rpms at the same speed with the TKO, depending on whether you run the TKO500 or the 600 (one is .64 overdrive fifth and the other is .68).
Old 11-19-2009, 02:38 PM
Ron Fox's Avatar
You mentioned when Doug Nash (now Richmond) came out with the 5 speed it's main benefit was less rpm drop between gears...so does the TKO have a drop off between gears?
Ron
Old 11-19-2009, 11:07 AM
Ron Fox's Avatar
I am still waiting on metal work to begin and the engine decision (among other things) has not been make just yet. I want a built 455 and my plan is to have Butler Performance in on the build. So when the engine time comes I will get with Butler and others to see what is the best choice for me. (which will be another thread in the future).
But it sounds like most everyone in here so far does not think Richmond is the way to go. Please keep the information coming on the experiences with Richmond and other transmission. Also please give all the benefits of the TKO's, etc.
Thanks.
Ron
Old 11-19-2009, 11:36 AM
Mkelcy's Avatar
Thanks.
You've gotten three responses from people who have driven both transmissions. All three thought the Tremec shifted much nicer than the Richmond. You've had the gearing explained and an example of the resulting rpm range given.
Here's where (I think) it gets to be you who needs to do some of the work if you really want an explanation of "all the benefits of the TKO's, etc." A simple search will get you lots of information.
That said, I'm surprised you still need further explanation given the the Richmond is 0 for 3 based on personal experience.
Old 11-19-2009, 02:32 PM
Ron Fox's Avatar
Here's where (I think) it gets to be you who needs to do some of the work if you really want an explanation of "all the benefits of the TKO's, etc." A simple search will get you lots of indformation.
Like I said earlier I am not a gear head and talking about the good and bad about a part or item in depth gives me better understanding and teaches me about cars in general. And I admit I do sometimes ask the same questions but it's just to learn more.
I appreciate all the help but with more opinions comes more knowledge for me.
And yes the TKO sounds like the way to go.
Ron
