Old 11-30-2009, 02:07 PM
Jack Maurer Jack Maurer is offline
Default T56 Magnum installation
Who makes a transmission crossmember for installation of a T56 Magnum transmission in a 69 Camaro? Speed Tech who took over ATS has a huge back order and likely will not have crossmembers available until Jan 2010.
Old 11-30-2009, 02:48 PM
Try Keisler Transmissions -- they might not list this part for your application so you might have to call them and make your inquiry.
Old 12-13-2009, 11:04 AM
Jon69RagTop Jon69RagTop is offline
Default Check out Projects
Look up 69 Camaro LS3 transplant. $50 raw kit from summit. 2 hours later your done.
Old 12-13-2009, 05:07 PM
Steve1968LS2's Avatar
When I put the Magnum in my car I used the same crossmember as I did for the old "first gen" T56.
In other words you don't need anything special. Here's a story of when we did the Magnum install, might be a few tips in it for you
http://www.camaroperformers.com/cama...ion/index.html
Old 12-16-2009, 07:17 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
http://www.bmrfabrication.com/F1_all.htm
