Closed Thread
Old 12-18-2009, 10:42 AM
No it wasn't. The new motor will have it plugged!
  #1012
Old 12-18-2009, 10:52 AM
HWY Nova HWY Nova is offline
Somewhere my math SUCKS Phone water! I've checked this three times and it comes out 473 --- but the actual displacement would - as Todd states - be 508
so what am I missing??
Bore: 4.300 in.
Bore Area: Pi X 4.300 X 4.300 / 4 = 14.522 sq. in.
Displacement/cylinder: 4.375 X 14.522 = 63.534 cu. in.
Total Displacement: 8 X 63.534 = 508 cu. in.
ET
62 Nova Coupe
62 Nova Convertible @ Ironworks Speed & Kustom
  #1013
Old 12-18-2009, 12:20 PM
66LS7's Avatar
66LS7 66LS7 is offline
That is going to be a killer motor, should really help loosing the extra weight on the track.
Randy(D&Z Customs LLC.)
[email protected]
1-262-347-9741
  #1014
Old 12-18-2009, 12:38 PM
70rs's Avatar
70rs 70rs is offline
Way to go Todd! I am looking forward to this chapter and can't wait to see a final parts list and then some numbers from the dyno!
  #1015
Old 12-18-2009, 01:38 PM
gmorris gmorris is offline
Then just make sure you run a racing filter with no internal bypass and a sturdy can. I use wix R series filters and they seem to be good quality.
  #1016
Old 12-18-2009, 01:43 PM
Yep, I run a moroso racing filter anyway. You should be good to go. My filter caught a ton of it, unfortunately I didn't know I had a problem until it was to late anyway.
  #1017
Old 12-18-2009, 01:50 PM
I have read that "normal" store bought filters can't deal with the pressures a good motor will make - say 70 lbs... and they can pop or blow... so running a "Race" style filter is smart insurance.
I run a cleanable stainless steel screen O'ringed type filter with magnets internally and remote mounted.... it filters 100% of the oil. However, all of that - won't save a motor that is determined to grind itself to death... But it sure SHOWS YOU that is happening!!! LOL
  #1018
Old 12-18-2009, 02:31 PM
Rybar's Avatar
Rybar Rybar is offline
Very cool motor Todd, really like the idea of shedding the BBC weight off the front with the alum block.
Have you thought about the spring rates having to be changed on the front end?
And have you thought about upgrading to EFI at some point?
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
  #1019
Old 12-18-2009, 02:44 PM
Luckily Prodigy accidentally put small block/lsx springs in the front anyway. I was actually contemplating changing to big block springs before I pulled the motor. Although after my last autocross I was really happy with it as is. I'm sure my coil overs will need adjusted so I should be in good shape chassis wise.
As far as injection goes, I don't have any immediate or future plans. I'd need to start over from tank to engine on my fuel system. I feel the carb is easier to deal with in a racing enviroment. It's easier to keep two bowls full than 60psi behind every injector ALL the time. Plus, I just chapped my wallet anyway! Is there a group for this sickness?
  #1020
Old 12-18-2009, 04:25 PM
This site is the group for that. We all share the same affliction! Thats going to be a sweet engine, plenty of power and a weight savings. This car just keeps getting better all the time !
Closed Thread
