Old 12-29-2009, 08:35 PM
aany001's Avatar
aany001 aany001 is offline
Default 1st gen subframe install questions
Guys what is the proper way of aligning my subframe to the body in my 69 camaro.I have searched the site but no luck........please help.
Steve
Old 12-30-2009, 05:45 AM
XcYZ's Avatar
XcYZ XcYZ is offline
The stock subframe? I believe the align rods that slide from the frame into the body at the firewall mounts are 5/8" (or are they 1/2"? Can't remember anymore, lol). Between that and cross measuring, you should be able to get it perfect.
Here's a pic of the alignment holes which are outside the body bushings:
My LS7 69 Camaro
Old 12-30-2009, 06:29 AM
aany001's Avatar
I did line up those holes and where should I use for cross measuring for squareness??
Old 12-30-2009, 08:16 AM
J2SpeedandCustom J2SpeedandCustom is offline
Here is a spec sheet for you.
Jeff Allen
J2 Speed and Custom
Old 12-30-2009, 11:17 AM
70rs's Avatar
70rs 70rs is offline
Nice work Jeff. When I get ready to do my second gen I will look you up.
Old 12-30-2009, 06:43 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Steve,
I just finished lining mine up today. I sent you a PM with my phne number. Call me. I can talk you through it a lot quicker than I can type.
Chris
Chris
