Old 01-04-2010, 09:28 PM
I'd just get the new sub..... I'd have to wonder if the spring is out of spec. Lube never hurts.
Old 01-04-2010, 09:40 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
Supporting Vendor
trying to understand the problem, if it "poped into place"
Or is it that the end of the spring is making it's way into a step in the frame? because those can vary, and the conical springs tend to have a smaller wire that can get cought in a small pocket, I would get correct conventional springs and shocks for the application.
www.pro-touringf-body.com
Old 01-04-2010, 10:20 PM
DFRESH's Avatar
DFRESH DFRESH is offline
It somehow popped into the spring bucket previously--probably when I put the full weight of the car against it on the ground--but when it did so, it wasn't lined up (or bottomed out against the "step" or indent) against the indent in the upper spring bucket--so it rotated some--by at least and inch or more. Now, as I go to reinstall spring, I cannot get it to butt up against this indent---it's almost as if the spring is to small to fit it in there correctly--it is close--but not close enough. It's the right spring and shock for the app.
Old 01-04-2010, 10:23 PM
DFRESH's Avatar
Hater. May try some lubricant on it---
Old 01-04-2010, 11:22 PM
70rs's Avatar
70rs 70rs is offline
Have you tried a REALLY BFH?
Oh, and A LOT of KY...I mean grease.
