Old 01-06-2010, 06:23 PM
Roger M Roger M is offline
Default Google is your friend
OK. All this talk about the Baddest 68 Camaro in the UNIVERSE got me to search. Here is the top 68 Camaro image that came up.
Now, If you just search Baddest 68 Camaro (without Universe), you will see Steve's car on the top row.
http://images.google.com/images?q=ba...N&hl=en&tab=wi
Old 01-06-2010, 06:53 PM
[QUOTE=72tunaboa;259430]OK. All this talk about the Baddest 68 Camaro in the UNIVERSE got me to search. Here is the top 68 Camaro image that came up.
LOL
Old 01-06-2010, 07:23 PM
Steve1968LS2's Avatar
Originally Posted by jmac View Post
What about Vinny's 68?
http://www.pro-touring.com/forum/sho...ight=VINNY%27S
I love this car, cause it's a big block!
And it seems to perform pretty well!
I knew I was forgetting one.. yea, that would be on my "baddest 68 Camaro" list
Old 01-06-2010, 08:11 PM
CarlC CarlC is offline
Originally Posted by Steve1968LS2 View Post
I'm in... just let me get that new 440 installed.. lol
What other "cool" 68s are out there? Velocity over at Ridetech is pretty badass.. I know I'm missing some.
I would run against this car.. after all I have nothing to lose. lol
If I win it's "Hey, I beat a million $$$$ Camaro!"
If I lose then it's "Hey, what do you expect, the guy had a million $$$$ Camaro!"
I'd still be bringing a trowel to a gunfight, and loving every minute of it. Thanks for the invite James. Put some blue tape over your windwings and we'll count yours as a '68 too. Just let us know when and where!
To each his own on builds like this. The fabrication and ideas on this project are great. Even if there are things that you don't like, there are lots of cool ideas that we could find ways to incorporate. Are there things I would change? Yes, but that may not fit what the owner of this car wanted. Sometimes appearances are forced to change or be out of sync due to the drivetrain requirements of the car.
http:www.vaporworx.com
Old 01-06-2010, 08:17 PM
And I could invite someone like Boris Said to drive all the cars just to make it fair... (I lost the Stig's number)...
Old 01-06-2010, 08:43 PM
Young Gun Young Gun is offline
Originally Posted by MtotheIKEo View Post
Are you familiar with rod ends? They can pivot freely inside the race, instead of the pivoting around a trunnion they are using the ball as the pivot. Works fine as long as you stay within the limited amount of misalignment for the given rod end.
Awesome, thats the answer I was looking for!
Colin Russ
Car Junkie since 1990
Old 01-06-2010, 09:31 PM
DFRESH's Avatar
DFRESH DFRESH is offline
This car had me at "All aluminum BBC dry sump". I choose to overlook the hideous wing because of this.
Old 01-07-2010, 05:51 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
It's definitely has the right moves to make it the baddest.
I'd like to know the aerodynamic specs. It might be the only first gen to not produce front lift.
http://www.camaro-untoldsecrets.com/...article_fs.htm
Old 01-07-2010, 07:45 AM
68protouring454's Avatar
Originally Posted by ironworks View Post
I like the build pics WWWWWAAAAAAYYYYYY better then the end product. But who builds a square tube race car, Think of how much unneeded weight that car has.
It is an honor to think Tyler's 50/50 Car would even be thought about in the "Best of the Universe" contest. But Greg, Just to be clear 50/50 has come a million miles from the abortion that some body put under that car however many years ago. That particular chassis ranks high on a whole other list of mine.
lots build from square. just about every trans am car is more square tube(main chassis rails etc) then round, also Lg's gt cars have alot of square in them as well.
it maybe uneeded weight, but there are limits to amount of lead etc that can be used, and weight can be good when its used in the middle of the car low to the ground between the wheels.
Jake's Rod Shop
Old 01-07-2010, 08:26 AM
rwhite692's Avatar
As to the fuel cell being offset to the pass. side, I don't see a big problem with that, since the intent may be to offset the effect of driver position/weight. Plus the oil tank is next to it so the combined weight of the two may be pretty well centered on the car, anyway.
The wing is indeed hideous looking, but may be quite functional depending on the intended use of the car. Full belly pan, QC rear, etc...the intent of the build sure seems to be to do some sustained high speed running, as in 200+....of course he will need the right tires for that but he may have them for all we know.
It would indeed be great if the builder/owner could get on here and explain his intentions for the car. Quite an impressive build.
Project update thread here:
My Lateral-G Page
My Shop Build:
